I have a forward facing web server with a web adaptor for Portal and a second web adaptor for ArcGIS Server.
I have a server behind the firewall with both Portal and ArcGIS Server on it. My security is allowing anonymous and both Http and Https on both Portal and ArcGIS Server.
So I understand I need a CA certificate on the forward facing web server. So do I need a CA certificate on the internal server on each Portal and ArcGIS Server? Or do I need just one CA certificate on the internal server?
I also don’t understand, if when you bind the certificate, if you bind it to the Default web site or the actual site for each Portal and again on Server?
Janie
