I shared a feature class and a file geodatabase table to my Enterprise Portal as a web layer. I need to have both the feature class and the table in a web map. When I make a map with the new Map Viewer, the table is nowhere to be found. But when I use Map Viewer Classic, the table is in the map, just like I need. But I need to use the new Map Viewer because Map Viewer Classic is of course obsolete.
I did confirm that both the feature class and the standalone table are listed in the map service's REST endpoint.
There's no editing involved - no versioning, no feature service, etc.
I am the owner of the web layer / service. And I am working on the web maps as myself, the same account that is the owner.
I'm using ArcGIS Pro 3.0.3
Enterprise 10.9.1 build 28388
My organization cannot upgrade to Enterprise 11 yet. In fact, the work I am trying to do with this web layer is part of our work to get all our map services running from Pro, as part of our preparation for upgrading. So I have to get this work done before we can upgrade.
I did see something on Esri Community from 2 years ago about related tables not showing up in the new map viewer, like Esri hadn't built this functionality yet. I don't know if this is related.
A crazy thing is that on another Enterprise Portal we have (the Dev one), an essentially identical web layer with a table DOES show up in the new map viewer. That Portal has the exact same version and build as the one I'm having the problem with (which is our Production portal), and the services have the same settings. I don't see how the new map viewer could be acting differently in the two Portals, but it is.
Does anyone know how to get the table to show up in Map Viewer? Is it a bug?
