I have 3 Dashboards embedded into individual Views in an Experience Builder app. (Had to use Dashboards rather than ExB to filter the data as I wanted, but that's a different issue!) All the dashboards and the ExB are pointing towards the same single dataset.
I would like to be able to use the ExB Filter widget to filter the dashboards to show data for certain areas - using an attribute for the Area_code in the dataset. Is this possible?
I have set up URL parameters in the dashboards and added that to the ExB embed code, but I'm not sure where to go from there. From what I can see, the ExB Filter widget does not pick up the embedded dashboards as a target widget, so there is no option to add an Action to the Filter. Any ideas or alternative ways round it welcome.
I know an option is to use category selectors in the dashboards to do the filtering there, but users would then have to re-select their area when switching between the Views.
