When launching a python script from a SQL Server Agent Job I am unable to initialize a product license (We are using ArcPro) which is causing my import arcpy statement to fail. I know its a long shot but do any of y'all have an idea on how to fix this?
-Ben
How are you managing your licenses? It gets a little tricky when using AGOL named users. I'm curious as to why you are using sql server agent to fire an arcpy script: we have a system user do it, and that system user is also a named user at agol so it can grab the license.
Is this script gong to be part of an on-going process that will be run as a Windows Scheduled Task?
Michael Volzl ; all of our scripts run as scheduled tasks not through sql server agent...
So we are running this script after an insert trigger is fired. We currently run it as a scheduled task but have received requests to have it run after records are inserted into a database. We have a named user license that is authorized to work offline on the machine.
I don't know how you would convince the license part that sql server agent is the same as the user name that runs your scheduled tasks. That's a funky one.
Would you consider an attribute rule that fires upon insert?
I would. Can you provide documentation for me to go down that rabbit hole? I really appreciate the help.
Attribute rules: Introduction to attribute rules—Geodatabases | Documentation
would that require that the Attribute Rule be run against a feature service where the enterprise geodatabase is the source?
Any attribute rule(s) are assigned to a specific attribute in the specific feature class. I believe if that feature class is a published, editable feature layer/service the attribute rules are fired back in the enterprise gdb, so you'd be good to go.
