As many of you know managing feature layer domains is a major time suck and tedious if you stick with a supported work flow. You can spend hours populating and organizing coded values using the AGOL UI. We have to maintain lists of pesticide applicators for ten or more contract crews that collect pesticide application data using Field Maps. So you can imagine how excited I was when ESRI announced that choice lists can be managed via the Field Maps web app form builder by uploading a CSV. I optimistically assumed that this improvement was about to eliminate our domain management issues. I was dismayed when I learned that choice lists can not be managed for view layers and can only be applied to hosted feature layers. We exclusively use view layers for field data collection to limit what features can be added, deleted and updated by field users. After further investigation I found that editing the choice list in the Field Maps Web app actually modifies the field's coded value domain. This was surprising since Field Maps form elements and associated settings are stored as part of the Web Map (as far as I am aware). This important fact is omitted from the documentation.
It would be great if choice lists (and the coded value domain) could be managed for view layers. It wouldn't be as odd as modifying the source data's domains since you can maintain different coded values for view layers already.
