Hi all, I'm fairly new to GeoEvent Server, and I'm having a heck of a time figuring out how to do something that, at least on the surface, seems like it should be straightforward.
I have two feature classes: one point feature class representing patrol vehicles, and one polygon feature class representing patrol areas. The goal is to update the patrol area's LAST_PATROLLED_DATE when a patrol vehicle intersects with it.
So far, I have successfully created a stream service reprenting the vehicles, and imported the patrol areas as GeoFences. Where I'm stuck is actually using the GeoFences (I'm assuming GeoFences and a stream service is the recommended approach).
How does one configure a process to be triggered when a vehicle enters a GeoFenced area? My hope is the input of this process would include the definitions of both the geofence entered, and the vehicle that entered it.
Update 1:
I"ve figured out I should be using a Filter element wired-up to my GeoFences, however I don't see any way to update the feature corresponding to the intersected GeoFence. Is there a way to query a feature layer in a GeoEvent Service?
Update 2:
In addition to the reply below I marked as the solution, I found this community post very helpful. The input connector used in the post is different, but everything else seems to apply.
