I'm trying to fix some old code we use to identify high crash locations. Between this year and last year the code has stopped working. I am getting this error.
Running script BelmontSelection...
Failed script BelmontSelection...
File "E:\Backup\CrashReports\2020\2020CrashDataFiles\Script\Belmont_Crash_Selection - Copy.py", line 88, in <module>
Field_Map_of_Join_Features = Lat + ' "' + Lat + '" true true false 16 Double 6 15 ,First,#,' + Output + "," + Lat + ",-1,-1;" + Long + " \"ODOT_LONGI\" true true false 16 Double 6 15 ,First,#," + Output + "," + Long + ",-1,-1;" + Street_on + ' "' + Street_on + '" true true false 254 Text 0 0 ,First,#,' + Output + "," + Street_on + ",-1,-1;" + Ref + ' "' + Ref + '" true true false 254 Text 0 0 ,First,#,' + Output + "," + Ref + ",-1,-1;Inj_Crash \"Inj_Crash\" true true false 4 Short 0 4 ,First,#," + Output + ",Inj_Crash,-1,-1;Fat_Crash \"Fat_Crash\" true true false 4 Short 0 4 ,First,#," + Output + ",Fat_Crash,-1,-1;BUFF_DIST \"BUFF_DIST\" true true false 0 Double 0 0 ,First,#," + Output + ",BUFF_DIST,-1,-1;Latitude \"Latitude\" true true false 16 Double 6 15 ,Mean,#," + Crash_Data + "," + Lat + ",-1,-1;Longitude \"Longitude\" true true false 16 Double 6 15 ,Mean,#," + Crash_Data + "," + Long + ",-1,-1;SumInjury \"SumInjury\" true true false 4 Short 0 4 ,Sum,#," + Crash_Data + ",Inj_Crash,-1,-1;SumFatal \"SumFatal\" true true false 4 Short 0 4 ,Sum,#," + Crash_Data + ",Fat_Crash,-1,-1"
UnicodeDecodeError: 'ascii' codec can't decode byte 0x82 in position 22: ordinal not in range(128)
Failed to execute (BelmontSelection).
Failed at Thu Jul 16 09:44:42 2020 (Elapsed Time: 19.90 seconds)
I have tried looking for and removing all non ascii characters in the data and the code but even after that and running the code from an old copy the error persists. How can i change the code so the decode error doesn't occur. It seems to be failing on line 88 where it tries to make the field map.
<SPAN class="comment token"># ---------------------------------------------------------------------------</SPAN>
<SPAN class="comment token"># Belmont_modelAll.py</SPAN>
<SPAN class="comment token"># Description: </SPAN>
<SPAN class="comment token"># Import arcpy module</SPAN>
<SPAN class="keyword token">import</SPAN> arcpy
<SPAN class="comment token"># Script arguments</SPAN>
Crash_Data <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetParameterAsText<SPAN class="punctuation token">(</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN>
Buffer_distance <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetParameterAsText<SPAN class="punctuation token">(</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">if</SPAN> Buffer_distance <SPAN class="operator token">==</SPAN> '<SPAN class="comment token">#' or not Buffer_distance:</SPAN>
Buffer_distance <SPAN class="operator token">=</SPAN> <SPAN class="string token">"0.05 Miles"</SPAN> <SPAN class="comment token"># provide a default value if unspecified</SPAN>
Selected_shp <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetParameterAsText<SPAN class="punctuation token">(</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">if</SPAN> Selected_shp <SPAN class="operator token">==</SPAN> '<SPAN class="comment token">#' or not Selected_shp:</SPAN>
Selected_shp <SPAN class="operator token">=</SPAN> <SPAN class="string token">"C:\Users\Transportation\Desktop\2020CrashDataFiles\Script\Output Files\\Selected.shp"</SPAN> <SPAN class="comment token"># provide a default value if unspecified</SPAN>
Freq <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetParameterAsText<SPAN class="punctuation token">(</SPAN><SPAN class="number token">3</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">if</SPAN> Freq <SPAN class="operator token">==</SPAN> '<SPAN class="comment token">#' or not Freq:</SPAN>
Freq <SPAN class="operator token">=</SPAN> <SPAN class="number token">13</SPAN> <SPAN class="comment token">#provides default value</SPAN>
Inj <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetParameterAsText<SPAN class="punctuation token">(</SPAN><SPAN class="number token">4</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">if</SPAN> Inj <SPAN class="operator token">==</SPAN> '<SPAN class="comment token">#' or not Inj:</SPAN>
Inj <SPAN class="operator token">=</SPAN> <SPAN class="number token">9</SPAN> <SPAN class="comment token">#provides default value</SPAN>
Fatal <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetParameterAsText<SPAN class="punctuation token">(</SPAN><SPAN class="number token">5</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">if</SPAN> Fatal <SPAN class="operator token">==</SPAN> '<SPAN class="comment token">#' or not Fatal:</SPAN>
Fatal <SPAN class="operator token">=</SPAN> <SPAN class="number token">4</SPAN> <SPAN class="comment token">#provides default value</SPAN>
<SPAN class="comment token">#Expression statement</SPAN>
Expression <SPAN class="operator token">=</SPAN> <SPAN class="string token">'"Join_Count"'</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="string token">" > "</SPAN> <SPAN class="operator token">+</SPAN> str<SPAN class="punctuation token">(</SPAN>Freq<SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="string token">" OR "</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="string token">'"SumInjury"'</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="string token">" > "</SPAN> <SPAN class="operator token">+</SPAN> str<SPAN class="punctuation token">(</SPAN>Inj<SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="string token">" OR "</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="string token">'"SumFatal"'</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="string token">" > "</SPAN> <SPAN class="operator token">+</SPAN> str<SPAN class="punctuation token">(</SPAN>Fatal<SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">#Have user input what the crash severity is called in the data table</SPAN>
crashSeverity <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetParameterAsText<SPAN class="punctuation token">(</SPAN><SPAN class="number token">6</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token"># Process: Add Inj_Crash Field to Data Table</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddField_management<SPAN class="punctuation token">(</SPAN>Crash_Data<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Inj_Crash"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SHORT"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NON_NULLABLE"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NON_REQUIRED"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token"># Calculate new field</SPAN>
<SPAN class="comment token"># Inj_Crash will show a 1 for an injury, not fatal; and 0 for any others</SPAN>
<SPAN class="comment token">#This field will be summed later to create and total number of injury crashes field</SPAN>
<SPAN class="comment token">#For Belmont County records there is one field for crash severity</SPAN>
<SPAN class="comment token">#1 is fatal, 2 is injury and 3 is PDO</SPAN>
<SPAN class="comment token">#Codeblock for injury calculation</SPAN>
codeblock <SPAN class="operator token">=</SPAN> <SPAN class="string token">"""def calc(sev):
if sev == 2:
return 1
else:
return 0"""</SPAN>
calcexp <SPAN class="operator token">=</SPAN> <SPAN class="string token">"calc( !"</SPAN> <SPAN class="operator token">+</SPAN> crashSeverity <SPAN class="operator token">+</SPAN><SPAN class="string token">"!)"</SPAN>
<SPAN class="comment token">#Process: Calculate field</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CalculateField_management<SPAN class="punctuation token">(</SPAN>Crash_Data<SPAN class="punctuation token">,</SPAN><SPAN class="string token">"Inj_Crash"</SPAN><SPAN class="punctuation token">,</SPAN>calcexp<SPAN class="punctuation token">,</SPAN><SPAN class="string token">"PYTHON_9.3"</SPAN><SPAN class="punctuation token">,</SPAN> codeblock<SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token"># Process: Add Fat_Crash Field to Data Table</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddField_management<SPAN class="punctuation token">(</SPAN>Crash_Data<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Fat_Crash"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SHORT"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NON_NULLABLE"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NON_REQUIRED"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token"># Fat_Crash will show a 1 for a fatal crash; and 0 for any others</SPAN>
<SPAN class="comment token">#This field will be summed later to create and total number of fatal crashes field</SPAN>
<SPAN class="comment token">#Not necessary now, but if a crash ever had more than one fatal crash, it would be necessary</SPAN>
<SPAN class="comment token">#Codeblock for fatality calculation</SPAN>
codeblock2 <SPAN class="operator token">=</SPAN> <SPAN class="string token">"""def calc(sev2):
if sev2 == 1:
return 1
else:
return 0"""</SPAN>
calcexp2 <SPAN class="operator token">=</SPAN> <SPAN class="string token">"calc( !"</SPAN> <SPAN class="operator token">+</SPAN> crashSeverity <SPAN class="operator token">+</SPAN> <SPAN class="string token">"!)"</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CalculateField_management<SPAN class="punctuation token">(</SPAN>Crash_Data<SPAN class="punctuation token">,</SPAN><SPAN class="string token">"Fat_Crash"</SPAN><SPAN class="punctuation token">,</SPAN>calcexp2<SPAN class="punctuation token">,</SPAN><SPAN class="string token">"PYTHON_9.3"</SPAN><SPAN class="punctuation token">,</SPAN> codeblock2<SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token"># Local variables:</SPAN>
Output <SPAN class="operator token">=</SPAN> <SPAN class="string token">"C:\Users\Transportation\Desktop\2020CrashDataFiles\Script\Output Files\\Model_Buffer.shp"</SPAN>
SpatialJoin_shp <SPAN class="operator token">=</SPAN> <SPAN class="string token">"C:\Users\Transportation\Desktop\2020CrashDataFiles\Script\Output Files\\Joined.shp"</SPAN>
<SPAN class="comment token">#User inputs fields that will be kept in final table</SPAN>
Long <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetParameterAsText<SPAN class="punctuation token">(</SPAN><SPAN class="number token">7</SPAN><SPAN class="punctuation token">)</SPAN>
Lat <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetParameterAsText<SPAN class="punctuation token">(</SPAN><SPAN class="number token">8</SPAN><SPAN class="punctuation token">)</SPAN>
Street_on <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetParameterAsText<SPAN class="punctuation token">(</SPAN><SPAN class="number token">9</SPAN><SPAN class="punctuation token">)</SPAN>
Ref <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetParameterAsText<SPAN class="punctuation token">(</SPAN><SPAN class="number token">10</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">#Create field map of joined features, sum inj and fatal fields</SPAN>
Field_Map_of_Join_Features <SPAN class="operator token">=</SPAN> Lat <SPAN class="operator token">+</SPAN> <SPAN class="string token">' "'</SPAN> <SPAN class="operator token">+</SPAN> Lat <SPAN class="operator token">+</SPAN> '" true true false <SPAN class="number token">16</SPAN> Double <SPAN class="number token">6</SPAN> <SPAN class="number token">15</SPAN> <SPAN class="punctuation token">,</SPAN>First<SPAN class="punctuation token">,</SPAN><SPAN class="comment token">#,' + Output + "," + Lat + ",-1,-1;" + Long + " \"ODOT_LONGI\" true true false 16 Double 6 15 ,First,#," + Output + "," + Long + ",-1,-1;" + Street_on + ' "' + Street_on + '" true true false 254 Text 0 0 ,First,#,' + Output + "," + Street_on + ",-1,-1;" + Ref + ' "' + Ref + '" true true false 254 Text 0 0 ,First,#,' + Output + "," + Ref + ",-1,-1;Inj_Crash \"Inj_Crash\" true true false 4 Short 0 4 ,First,#," + Output + ",Inj_Crash,-1,-1;Fat_Crash \"Fat_Crash\" true true false 4 Short 0 4 ,First,#," + Output + ",Fat_Crash,-1,-1;BUFF_DIST \"BUFF_DIST\" true true false 0 Double 0 0 ,First,#," + Output + ",BUFF_DIST,-1,-1;Latitude \"Latitude\" true true false 16 Double 6 15 ,Mean,#," + Crash_Data + "," + Lat + ",-1,-1;Longitude \"Longitude\" true true false 16 Double 6 15 ,Mean,#," + Crash_Data + "," + Long + ",-1,-1;SumInjury \"SumInjury\" true true false 4 Short 0 4 ,Sum,#," + Crash_Data + ",Inj_Crash,-1,-1;SumFatal \"SumFatal\" true true false 4 Short 0 4 ,Sum,#," + Crash_Data + ",Fat_Crash,-1,-1"</SPAN>
<SPAN class="comment token"># Process: Buffer</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>Buffer_analysis<SPAN class="punctuation token">(</SPAN>Crash_Data<SPAN class="punctuation token">,</SPAN> Output<SPAN class="punctuation token">,</SPAN> Buffer_distance<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"FULL"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"ROUND"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NONE"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token"># Process: Spatial Join</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>SpatialJoin_analysis<SPAN class="punctuation token">(</SPAN>Output<SPAN class="punctuation token">,</SPAN> Crash_Data<SPAN class="punctuation token">,</SPAN> SpatialJoin_shp<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"JOIN_ONE_TO_ONE"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"KEEP_COMMON"</SPAN><SPAN class="punctuation token">,</SPAN> Field_Map_of_Join_Features <SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"INTERSECT"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token"># Process: Select</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>Select_analysis<SPAN class="punctuation token">(</SPAN>SpatialJoin_shp<SPAN class="punctuation token">,</SPAN> Selected_shp<SPAN class="punctuation token">,</SPAN> Expression<SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">#Delete local variables</SPAN>
<SPAN class="comment token"># Process: Delete</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>Delete_management<SPAN class="punctuation token">(</SPAN>Output<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"ShapeFile"</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>Delete_management<SPAN class="punctuation token">(</SPAN>SpatialJoin_shp<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"ShapeFile"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
