Hi there,
I work for a government organisation that uses proxy file setting in IE and unable to use Survey123 on Windows without the Proxy Server enabled and settings filled in Connections->LAN Settings. At the moment, this policy is not going to change.
Is it possible to get additional configuration placed in Survey123 & Survey123Connect to allow this setting to manually added?
I hope the logic would be
- accept the custom configuration first
- proceed with current implementation if not found
Anthony
