I have a repeat question in a qc plot survey. For some reason when i open the survey from the inbox, outbox or draft folders the data from the first question is always lost.
I have been testing this with the bare minimum questions and it still seems to be a problem. Being able to access the original data for updating is a key requirement and the repeat question is a tidy way of capturing this information
Is this part of the bug mentioned in previous posts or am I not constructing the query correctly in the bind::esri:parameters column?
I have attached a copy of the survey.
We are using Survey 123 connect Version 3.0.142 and app version 3.0.149, i have tested this on ios, android and survey 123 for desktop.
Thanks in advance.
Rory
