Hello
I'm designing a survey which users will need to complete in 2 parts, at 2 separate times. I need to record the time of completion for both parts, and if possible I would like for the date and time to automatically populate.
However - if I use now() as the default value for the fields, the time set at first completion is then overriden by the time of second completion.
From speaking to an ESRI trainer earlier in the week, it *may* be possible to set a conditional calculation on the first field (ie 'if ${datetime1} is empty, now(), ignore') however I'm struggling with syntax to make this happen.
Has anyone encountered a similar problem or could offer some suggestions on how I can solve this issue?
Thank you in advance.
