I have a Form in which I capture the user name, the current date and I make a calculation of the next 5 days. I then place this value as a constraint in a different field.
In Connect, it works fine.
In Mobile/Desktop, if I access the survey as Collect, fields work fine. As soon as I try to use it as Inbox (which is what I want as there is a part that precedes this form) and place the above values in read-only mode, nothing is calculated.
If they are not in read-only mode, it works as intended only if I press this
Any ideas what I am doing wrong?
I obviously want them in read-only mode so the user does not change them.
Thank you,
George
