I don't want respondents selecting any of the same choices for Question 1 and Question 2 (both of which are select-multiple from the same list of choices). In theory I would use a cascading select however that's only possible for select-one questions. Therefore, I'd created a question (Q3) to check to see if responses to Q1 and Q2 are the same and provide a warning as necessary.
Q3
Calculation: if(${Q1} = ${Q2}, "same", "different")
Constraint: .!="same"
Calculation Message: Response to Q1 and Q2 cannot be the same.
First problem:
Before I answer either Q1 or Q2, Q3 defaults to "same". When I start selecting responses to Q1, Q3 updates to "different". When I select responses to Q2 however, Q3 does not update/change - regardless of my selection to Q2. It seems to only calculate once. How do I get the Q3 calculation to auto refresh when response to Q1 or Q2 are made/change?
Second problem:
The calculation above should only look to see if Q1 and Q2 are an exact match. I actually need it to identify if any of the same responses are checked. For example, if answers to Q1 are A1, A2, A4 and answers to Q2 are A1, A3 I need my calculation to be "same". I think adding in a regex is the way to do this but how to I specify this?
James Tedrick? Ismael Chivite? Anyone else have a solution to try?
