I have created a spatial view in an sde-enabled database. The view works fine, but when I try to register the view with the geodatabase using ArcCatalogue I get the error:
ERROR 001050
Either registered with geodatabase already or cannot open the dataset.
I have not registered the view before, and I do not understand why the "register with geodatabase" tool cannot open the dataset, if that is the problem. There is no more detailed information about the underlying cause of the issue.
I'm using ArcCatalogue 10.5.1. Registering tables and featureclasses works fine. The issue is only seen when trying to register views with the geodatabase.
Also, I don't know if this is related to the issue, but for some reason my view shows up with the type "SDE Feature Class" in ArcCatalogue, even though I haven't registered the view.
Does anyone have an idea of what the problem could be here?
