I have a form that uses a bar_code to populate a form via PULLDATA(). If the barcode isn't reading/working I want to allow a the user to pick from a SELECT_ONE. How can I structure an if...then statement to say... IF BAR_CODE is != "some_default_value" (barcode IS working) THEN set SELECT_ONE to NULL.
If the bar_code cannot be read then have the user pick from the SELECT_ONE. I have attached a form.
Thanks.
OK, thanks. How do I make one of the "non-relevant"? The way I have it working now is if someone picks select_one of say "1234", when they then scan a bar_code of "6789", the old value of "1234" is still shown to the user in the select_one. this dosn't allow the coalesce() to work since both fields have values. Is there a way to expose a RESET. I don't want 2 values to be saved with form.
You won't be able to have the questions set each other to null - that would create a circular calculation reference and there isn't a good way to set a question to null. You can set half of the operations in place (i.e., if the dropdown has a value, make the barcode question non-relevant).
The coalesce() function automatically gets the first non-null question of the two. With the way provided above (barcode, dropdown) if the barcode question is non-relevant it will have a null value and automatically be ignored. If the barcode question has nay value, the dropdown question is ignored.
Wow, that coalesce() function looks powerful. I will take a look. The other part of the question is how can I RESET the values of a Select_One to NULL or none? If you use a bar_code I want to set the select_one to null. If you pick a select_one I want to set the Bar_code value to NULL.
Hi Johnathan,
I would suggest starting by having 3 questions to resolve the ID:
1) The barcode question (id_barcode)
2) The select_one to manually pick (id_list)
3) A calculate question to select the non-null value using the coalesce() function (id_final)
coalesce(${id_barcode}, ${id_list})
Then you can use the ${id_final} with the pulldata functions. I would suggest having both id_barcode and id_list have the bind:esri:esriFieldType set to null so you don't have 3 different id columns writing to the table.
Los miembros registrados pueden publicar, seguir actualizaciones y más. ¿Nuevo aquí? Regístrate gratis.
