I have an question on controlling Cascade Select option.
There are around 10,000 Plots to be surveyed in the respective villages in the reality.
Approx. 30 Surveyors would be working using Survey123 App. Every Surveyor will be assigned manually some set of villages and respective plots for surveying.
In each Village, around 100 to 150 plots are available to survey. There is a higher chances of getting the data repeated for the same Plot multiple times by same surveyor or others as the Survey123 App is same for everyone.
Is there any way to control the Plot Number not to be available in the Plot Drop down , if Plot number is already surveyed and submitted back to feature service.
Or, is there any workaround to avoid this plot number at the Survey123 Field App or any other approach for this kind of survey.
Attached Sample XLSForm for ref.
Appreciate your early response.
Sanjeevi
