I'm trying to create a power automate workflow using a Survey 123 form and I seem to be missing fields in the dynamic content when connected to the form. I want to insert the "creationdate" field that is automatically created within the layer and I don't see that. I see the global IDs and other fields that is auto created for the layer but not creation date.
The other thing is I have a drop down with an other, where the person than can type in the other info. In the layer fields the field that contains the drop downs is "type_water_issue" and then if a user selects Other in that field, then what the user types in as a value is saved in the "water_issue_other" field. I can easily shows both fields in table view of arcgis online and display on pops and what not. However in the power automate dynamic content list only "type_water_issue" is being an option. So what the user typed in is not coming across to my google documents.
