In survey 123 I accidentally delete my Survey, but I was lucky enough to have saved a copy of my File Geo Data Base prior to deleting survey. I went through the steps to recreate the survey using my copy of the File Geo Data base, so now the creation date shows as yesterdays date. You would think this shouldn't be a problem except there is a lock on creation date field so that you cannot change the field to be something different in my case that would be the Inspection date, and you can only filter by creation date in Survey 123. Anyone know of a good work around for this?
