so i am trying to automate the generation of reports from Survey123 using the feature repoting API (found it documented on the BETA site) and it works great it will pull back all my questions the same as if you ran it manually from within Survey123 website. but as soon as i add any map or photo element it wont generate the report, yet you can manually generate the report from the survey123 website using the same template and it works fine...
this is one of the errors i'm getting:
Failed to print map for ${$shape|mapSettings:"6exxxxxxxxxxxxxx":1500|size:350:350}. waiting for function failed: timeout 180000ms exceeded
any ideas?
Stu
