ArcGIS Pro 2.4
Like so many others, my job is to create and test data and processes, first in our test environment(s) and finally in our production environment(s). And I suspect like so many others the difference between our test and production environments is some variation in the path name. For example, I create locators in :
\\someServer-t\arcgisresources\common\geocode ( a test env and then copy them to):
\\someOtherServer\arcgisresources\common\geocode (which is a production env)
If I add both of these folders to ArcGIS Pro, in a catalog view or pane, they both show up simply as geocode:
Is there a trick to renaming these so I can actually tell which is which? I tried adding the actual paths but ArcGIS Pro won't accept special characters; I tried just adding a T or P as a prefix or suffix, and that doesn't stick. Is this a designed limitation? If so, maybe the rename option should go away? (Maybe this is ideas material?)
As an example, it's possible in ArcCatalog:
Kory Kramer
