Hello, I have the following question.
How can i set up a dateformat for a infowindow? Right now my problem is the infowindow is showing a incorrect timezone, (-3 hr to my current timezone), so i need to fix it.
Here is my code:
<SPAN class="keyword token">let</SPAN> chInfoTemp<SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">InfoTemplate</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
chInfoTemp<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setTitle</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"<b>Current:</b>"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">let</SPAN> chInfoContent <SPAN class="operator token">=</SPAN>
<SPAN class="string token">"<div style=padding-top: 10px;><b>Starting: </b> ${initial_date:DateFormat(datePattern:'d MMMM yyyy, HH:mm:ss.', selector:'date')}<br></div>"</SPAN><SPAN class="operator token">+</SPAN>
<SPAN class="string token">"<div style=padding-top: 10px;><b>Final:</b> ${er:DateFormat(datePattern:'d MMMM yyyy, HH:mm:ss.', selector:'date')}<br></div>"</SPAN><SPAN class="punctuation token">;</SPAN>
chInfoTemp<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setContent</SPAN><SPAN class="punctuation token">(</SPAN>chInfoContent<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>Thanks in advice!
