Looking for a way to programmaticly stop/stop the AcrGIS server Service with a batch file. Basically, we edit into a FGD, then would like to copy that FGD to another location on the network. This new location would be what is served out via Server/Portal. we have found that the FGD coping process cannot happen unless the ArcGIS services are stopped briefly. We tried using the AGSSOM.exe utility, but it is not clear that this .exe can be used in version 10.6.1. We have also tried using NET STOP and SC commands, but it is not practical as these seem to need to "run as administrator" . Might there be any suggestions? thanks, James
