I have prepared the survey form using the soil sample data as attached the screenshot below for the reference but now I want to add the sample location for each repeat section using we were using a GPS device.
I do design a field that will basically, when you click on it, it will populate with the current location of the iPad. And then continue down, answering all these survey questions that are already here. and then when you go to the next repeat. that location field will be blank again,over to the next spot. And that's where you're going to, again, click on that field or a button next to that field to lock in the location for that new soil sampling spot.
Does it possible to add location for each sample outside the repeat in survey 123 not inside the repeat.? so, every time I can change the location for new sample
