Hello! I'm trying to use a method I've used before for setting up photo questions that only appear when a previous one has been filled, to give users the options to submit multiple photos if they need it.
For example, once(${Photo1}>'') is what I put in the "Relevant" field, and this has been working fine for my needs. However, today I updated my version of Survey123, and after publishing a survey noticed that all of the questions using this were showing up now in the browser version of the survey, regardless of if the referenced field had been filled or not. This issue isn't happening on mobile devices, where the survey is still appearing as intended.
My surveys that use similar set ups published with earlier versions of Survey123 are still working correctly. Is this a known bug, or are there any workarounds?
