I have a survey123 Connect file that get's an error when loaded in the web app, but seems to work correctly at least in the Survey123 Connect test.
The error is: "Error Initializing Form":
- TypeError: Cannot set properties of null (setting 'disabled')
What do I know:
1) Through process of elimination, I have determined that the cause of the error is from three rows (20 - canyon_user, 22 - what_areas_resident, 23 - what_areas_non_resident), specifically in their "Relevant" fields.
2) It seems that no matter what I put in the relevant field for those three questions, it still throws the error
3) It doesn't have the error when I delete the contents of the relevant fields
I'm very confused why this might be happening as I have other relevant fields within the survey, and I don't have any special settings on any of those three fields. I have tried publishing from a different computer with an older version of survey123 connect with the same result, I am currently on version 3.21.62.
I am attaching the .xlsx form for reference, I made the survey public for now while I troubleshoot: https://survey123.arcgis.com/share/54dcf422ad3343a2b937d1ecb44ad596
