Hi, I'm hoping someone with more Survey123 Connect knowledge and skill than I can assist with this.
I have a feature layer which consists of a point layer and a related table. I have made a survey from this within Survey123 Connect. The related table is within a repeat and the point layer data outside.
Within the survey, I would like to mix some of the questions that direct to the point layer and the related table. This will make it read much more sensibly to the surveyor.
Eg: Point layer fields: 1, 2, 3 /// Related table fields: 5, 6, 7
Currently the survey reads as: 1, 2, 3, (begin repeat) 5, 6, 7 (end repeat)
I would like the survey to read: 5, 6, 1, 2, 3, 7.
When I try to make two repeat groups I get an error. Understandable as it is using the same 'name' (related table name) twice. I have also tried to add a group within the related table repeat but this does not work either as it looks for those fields within the related table rather than the point layer.
Making multiple related tables would be unsuitable. I am considering adding some dummy fields to the related table and using pulldata functions to put this data into the point layer, but this is not an ideal workaround and will make this survey more complicated than it needs to be for future survey years.
Does anyone have any ideas on how to mix survey questions that direct to different sub-layers?
Any help or advice greatly appreciated!!
