I'm trying to create a survey where the users select different choices from an image map and I use the selections as a filter in the choice filter column. The image map is a select multiple question so I know I have to use selected() in the choice filter. During my testing, I noticed that when I select the first choice the filter works properly, but any other choice doesn't display until I unselect an additional choice. I'm not sure if this is a bug or if this functionality works with an image map. I've attached my form from the image map sample.
