For some of our features, our symbology is based on a field that is calculated in Field Maps via an Arcade expression. The Arcade formula that determines the symbology type is based on the values of five other fields. When one of those five other fields is edited in Field Maps, in iOS only, we get a pop-up alerting "Changing Feature Type - You are changing the feature type. Would you like to keep your current values (where possible) or reset to defaults?" that then has the option to select Keep Current Values or Reset to Default Values.
We do not get this pop-up for features whose symbology is based on an editable field. We only get this pop-up for features whose symbology is based on a calculated field that is based on the values of other fields.
We do not want this behavior. But we definitely want to be able to use iOS products.
Is there a way to disable this behavior in Field Maps in iOS?
We are using Enterprise 11.1. We plan to upgrade to 11.3 in a few weeks. Maybe this is a bug that is resolved in 11.3???
