I've been using Survey123 Connect for the last ~6 months and feel pretty comfortable with it, but I just recently started dabbling with the Dashboard. I currently have 125 surveys created for calibrating different tools and devices and they all have the same "Status" field with the choices of Review and Finalize, and the same "Job ID" field that is a text type element.
I was hoping to use the Dashboard to track the status of specific jobs by showing how many of the surveys for a specific job are in the review step vs how many are finalized. What I have so far is a Sidebar that lists all my Job IDs, and I've figured out how to connect the selection on the side bar to a gauge element in the Body of my dashboard. I also have a gauge for each (I've made 3 of my 125 so far) survey that shows the data I wish to show. When a job is selected on the sidebar, it will show how many of that particular item has been submitted for that particular job as well as how many of those items have been reviewed vs. finalized. Currently, if the gauge is for an item that was not calibrated for that particular job, it will just show "No data".
The big issue I see is if I were to continue down this path, there would be a ton of useless information on the page as most jobs only calibrate ~10 different item types at most, meaning there would be over 100 gauges on the screen that will all be empty, showing "No data".
Is there a way to make Dashboard elements dynamic? I would like to make it so when a job is selected on the side bar, if there were zero items with that Job ID for a particular survey, it hides the element completely.
