I'm looking to link a few surveys.
Survey 1 is used to establish a 'site' through a point on the map, some sort of 'id' for this point, and a physical address for this point.
Survey 2 is used to establish specific points at a 'site'. The first question of this survey will be a dropdown menu with the possible answers being the result of 'id' for survey one. The two need to be linked so that each point in survey 2 carries with it the address and 'id' from the first survey.
Survey 3 is used to collect data about points from survey 2. Similarly, the first question of this survey will be a dropdown menu with the possible answers being the result of the second survey. The same fields from survey 1 should be carried through as well as the georeferenced point and some other fields from survey 2.
Survey 1: 'ID', 'address'
-> Survey 2: georeferenced point, 'point ID'
-> Survey 3: data about 'point ID'
What's the workflow for something like this? Can you provide any previous examples of documentation that would be relevant?
All The Best,
GJH
