I'd like to create an EB app involving a single WebMap where the layers are organized thematically. So far, I've been able to use multiple map layer widgets with layer customizations to generate this breakdown. This is in ArcGIS Online since the ability to customize layers within the map layer widget isn't in Enterprise yet. I'd then like to use one or more table widgets in conjunction with the map layer widgets. However, there doesn't seem to be a way to connect these widgets for my desired outcome. I want the layers present in the table widget to filter according to the layers within a specific map layer widget when said widget is opened.
For example, if my 'themes' are roads, sewers and buildings - each theme with its own map layer widget containing associated layers (see attachment for visual) - if I were to open only the road layers theme, I'd want the table to filter layers down to only the road layers. Without something like this occurring, the table widget will have a massive number of layers and tables to search thru to account for all layers involved in the map.
It looks like the only Message Action for the table widget is 'record selection changes' which would not be the case in this example.
Is it possible to do what I'm trying to do?
