I have a survey with one repeat, and in each repeat there is an attached image.
The users were supposed to submit 1 survey per block with repeats. This generated a report per block with summary calculations based on repeat answers. However some users ended up doing half a block and submitting and then the other half on a different survey.
I want to merge these two records together, or add the repeats from the one survey on to the other. Is there an easy way to do this?
