Rebecca Strauch
I'm tagging Rebecca because of the conversation here: Custom toolbar that contains Python Scripts
I have been playing with the Python Add-In Wizard, and I have created a toolbar with some menus and buttons. I am having trouble getting the buttons to work, though. I've followed Rebecca's instructions (here: Python add-ins vs. .NET add-ins?), as well as the attached PDF to try and use an existing python script within my toolbox, but the button just shows up as missing when I install the add-in and run ArcMap. I've even tried pasting the entire code from the script directly into the onClick function, and that just does the same thing.
Is this a common problem? Is this indicative of a common issue, or could it be a vague error that would be harder to diagnose...? I read somewhere that the missing designation could mean that there is some sort of syntax error in the code, but the scripts work on their own...just not whenever I try to associate them with a button on the custom add-in toolbar.
Thanks you!
