I am trying to use the expression below to pull data on from a feature layer, I have used x to protect some data but otherwise the formula is exact:
pulldata("@layer", "getValue", "attributes.xyz", 'https://services9.arcgis.com/P6kyywx46o75oKam/arcgis/rest/services/xyz/FeatureServer/0',concat("ReferenceNumber ='",${ReferenceNumber},"'"))
The problem is, Connect is generating a form however, instead of a field into which information is populated, I am getting the below error:
SyntaxError: Invalid regular expression flag 'R' in expression: *repeats formula above*
Only problem is, I don't know what that error message means.
Any help?
