Hello all,
Is it possible to use two different fields to generate values and have one field be priority / overwrite?
I am using an IF statement that looks at two previous fields to determine if water service line needs replaced based on bothsidestatus. That part works fine; however, I am wanting the "length(${scheddate}>0 Scheduled Replacement" to overwrite / or take priority over the bothsidestatus.
In better words, if the user schedules a replacement date in either utility or customer side with this schedule date field, I want the calculation to show the status as "Scheduled Replacement" rather than "Still Identifying Material Types / Needs Replaced / Doesn't Need Replaced" options. I tried to move the string-length option to the front of the calculation but kept getting the error "If statement needs 3 conditions, and you only have 1 condition".
Calculation:
if(${bothsidesstatus}='Unknown' , "Still Identifying Material Types", if(${bothsidesstatus}='Non-Lead' , "Doesn't Need Replacement", if(${bothsidesstatus}='Galvanized Requiring Replacement', "Needs Replacement", if(${bothsidesstatus}='Lead', "Needs Replacement", if(string-length(${custscheddate}>0 or if(string-length(${scheddate}>0, "Scheduled Replacement", "Still Identifying Material Types"))))))))
Thank you, if you need a copy of my survey or anything else please let me know
