Hi all,
I am struggling here to understand why the report that I have created fails at showing the photos from my survey.
The images in the survey come from an image type field and multiline is selected for the appearance.
The report that I created is pretty simple and at this point I am aiming at either pass into the report the first photo or all the photos.
I have tried all sorts of syntax but the report keeps failing and brings an empty box while every other field in the report gets pulled correctly.
It is not a hosted feature but I'm hoping that is not the reason why it is failing. I also added the report template, the xls for the survey and the report with the failing image field.
Thanks a lot in advance
