ArcGIS Survey 123 Version 3.18.123
I'd like the users to see the Geopoint map window visible by default, when they first open the form.
At the moment, when users open the form they need to click the little map sign to open the map.
Is there any option to set that visibility by default in Survey 123 Connect?
Edit: I know that once you select a point on the Geopoint map, then the map element stays visible in the from. I just want the map to be visible without interaction from the user.
