Hi there. I'm building a simple ExB app and have two issues with the Search widget which may be related (if not, I can post them separately). The widget is looking at two different data sources: a map layer and World Geocoding Service.
- The first selection the user makes from the result panel simply seems to re-filter the results (even if the original search term was an exact match for a result), requiring them to click the desired result a second time in order to trigger the other widgets.
- After the second (successful) selection, the results panel remains visible, obscuring the top of an Editor widget which sits directly below. This requires the user to identify and click the small Collapse button at the bottom of the results (I am using the Compact results panel option).
Am I missing some configuration option to address one or both of these issues? If not, I can add these as Ideas.
Thanks!
Derek
