We have multiple Enterprise GDBs, all being edited in ArcMap. We are looking at moving our Gas GDB from Geometric Network to Trace Network (UN is not an option now), or even just dropping network all together, to start editing in ArcGIS Pro. However, we will have many in the organization that will still be using ArcMap for other GDBs and will still likely need to view Gas GDB. Once you've moved your GDB to editing in ArcGIS Pro and setup your Pro attribute rules, can the GDB still be viewed/accessed by ArcMap users? We use Geocortex for a citywide map viewer, so I figure we will need to republish map services from Pro for that. Just trying to understand if an organization can still have feet in both environments, since moving the entire City over to Pro (Water, Wastewater, Transportation, Gas, Electric, Engineering, Parks, etc, etc) at the same time does not seem feasible..
