Hello i just found a bug at the moment of installing arcgis with pip or pipenv, no matter if i try with or without dependencies the error is the same
error in arcgis setup command: 'install_requires' must be a string or list of strings containing valid project/version
requirement specifiers; [32m[1mExpected[0m end or semicolon (after version specifier)
keyring >=19,<=21.8.*
note: This error originates from a subprocess, and is likely not a problem with pip.
error: metadata-generation-failed
× Encountered error while generating package metadata.
╰─> See above for output.
note: This is an issue with the package mentioned above, not pip.
hint: See above for details.
[0m
This is likely caused by a bug in [32marcgis[0m. Report this to its maintainers.
