Hello, I am trying to utilize the ArcGIS Unity C# API. I've gone through the tutorials, and right now I'm trying to utilize my own 3D models with their own textures as a source for the 3DObjectLayer I want to put on top of the map.
All of the tutorials only use custom ArcGIS URLs as sources, and no other tutorial out there shows how to use anything other than those provided URLs. I want to be able to create my own custom layers with my own models, FBX files of Toronto and New York , but every time I try to use them as a source I get an error
ArcGISLayerViewState buildings changed to : Error (IO error.)
Additional info: Unable to open or read file, it may be in a different format or corrupted: [user directory]/Assets/Materials/Toronto_FBX_files/Toronto_N_0.fbx
UnityEngine.Debug:Log (object)
Is this something that is intended to be used with ArcGISPro? I currently don't have access to the program in my company, and I see that the URLs provided give the same JSON data that things like this do (https://www.arcgis.com/home/item.html?id=ca0470dbbddb4db28bad74ed39949e25), but using those don't seem to work either.
What's the intended workflow in utilizing different sources for these layers? If it's URL based, how do I generate the URL I want for my 3DObjectLayer, and if I am able to utilize files like FBX how do I utilize those as sources?
