Hello. I need to make an automation inside the Survey123 form that will autocomplete some of the answers based on the answer from a question. I'm not so advanced in working with Survey123 and I need some help to make this happen.
Attached you can find the xls form from the survey.
What I am trying to achieve is: when I select "no" to question 7.1, the automation to select "no" to a couple more questions (1.1; 5.2; 6.4; 6.5.a; 6.5.b; 6.5.c; 6.5.d; 6.5.e; 6.5.f; 6.5.i; 7.16, 7.18). With the knowledge I have right now, I need to make a calculation for this.
Can someone please explain to me what exactly needs to be done to achieve this automation?
Thanks and regards.
