Noticing some weird behavior and hoping someone can shed some light on it. In a survey I'm working on, a map is chosen based on a drop down menu. This is working just fine.
I'm trying to geofence where people can place a pin in those maps. When I did the first map (with no if statement) it worked great. But now that I'm trying to do it with other maps, it seems to always default to the first item in the if statement. For example, in the code below, even if I choose "map2" and click somewhere, I will get the objectid of whatever is in the location in map1. Now, if I unselect map2 and select another map and then reselect map2 without clicking in the map, it will give me the correct answer - once - the next time I click, it again shows me the objectid from map1. Any ideas?
Example code:
if(${mapchoice}="map1", pulldata("@layer", "getValueAt", "attributes.OBJECTID", "https://urltomap1/FeatureServer/1", ${location_of_problem}),
if(${mapchoice}="map2", pulldata("@layer", "getValueAt", "attributes.OBJECTID", "https://urltomap2/FeatureServer/1", ${location_of_problem}),
0))
