I'm in the process of implementing an automated Survey123 report generator using the Survey123 REST API. I have the process working for the most part but I'm having an issue with my reports erroring out after I submit the job. When I query the status of the job I get an error message as follows:
"messages": [
"An error occurred when checking the report template. Failed to parse `${location}` since `location` cannot be found in the current parsing scope. "
]The 'location' field refers to a geopoint question, and if I remove the field reference from the report it then errors out on an image question. If I remove all references to images & spatial fields the report generation succeeds, and I'm able to save the report fine.
The problem here is that the exact same report runs fine if I generate it manually from the Survey123 website, which I figured is also using the API, so I'm wondering if there's a step I'm missing in the process which would solve this issue.
Happy to provide any files to support this. Any help is appreciated.
Nathan
