Anyone ever have subject error in processing Images with Drone2Map, being same error per post in ArcGIS Pro Raster options:
https://community.esri.com/t5/arcgis-pro-questions/ortho-mapping-block-adjustment-unsolvable-images/td-p/1030045
Getting on 2 seperate projects today, running RAW OBS. and Image Tags from DJI P4Pv2. Camera Calibration comes back valid. Yet Log file is returning Qty. of UNSOLVABLE IMAGES REMOVED message, then after "Estimating Initial Orientation and Camera Parameters..." message..... get the general ERROR 999999 with next line message of [GP][0][Error] Failed to execute (ComputeCameraModel) then "Geoprocessing Failed for Computing camera model".
Seems to be a notable result from ArcGIS Pro Raster options, yet Drone2Map (D2M) ?? using v2022.1.1 (patched).
Thanks, in advance.
