OK, so I can't get search to display the data from the source URL -- or from any source for that matter. The dropdown is empty. Troubleshot this with a colleague who was successful using the same exact XLSForm. Literally, the same form. Seems that the problem may be with my local Survey123 Connect application (?) but I cannot find the source of the issue. **Also, I am not experiencing any other issues w/ generating and publishing forms through Connect apart from this one item.***
- Survey123 Connect 3.14.274
- Advanced Template -- attached
Spent too many hours trying to figure this one out -- any help would be greatly appreciated.
UPDATE* Tried using search with local CSV and was successful. Problem remains when attempting to use URL.
UPDATE2* Uninstalled and reinstalled Connect but still no-go. Published a fresh copy of the survey and downloaded to Field App but not able to see values there. However, I opened the survey in a browser and WAS ABLE TO VIEW THE DROPDOWN VALUES THERE. Unfortunately, I need this running on the Field App.
UPDATE3* My collage is now seeing unusual behavior with this as well. Strangely, if we log out of the Field App (both the ArcGIS Online and organizational login) then the proper behavior is seen. Same with Connect - you have to log out to see it function properly.
Still looking...
