Is is possible to use a photo taken in a previous question in a survey to act as a default for an annotate question. I have surveyors who go out to a location, fill in some basic information, and take a photo of a location during daylight. They then want to annotate this photo later on during night-time to take records for bat surveys. The annotate is inside a repeat as there may be multiple records taken at the same time but needs to be shown on the "daylight" photo as it would be too dark to take a new photo at this time. There is the option of "select a file" but the photo taken previously is not visible in the android app in any of the folders (presumably as the survey hasn't yet been submitted or is stored in a different location.
If there is an option to use the earlier question image as a default background that would reduce the need to take a new photo or hunt around on the phone's file system for a photo. i cant seem to find out how it would work from the documentation, only the below is mentioned such that you would need to have an image in the surveys media folder already
"Defaults and calculations behave differently with image questions using draw and annotate. If the file name of an image in the survey's media folder is used as a default value or the result of a calculation, the image is used as an initial background for the canvas. With annotate, this image is replaced by a provided image, and it only displays if the user specifically declines to provide an image, or resets the image once already provided."
