I am running into an issue where callbacks in Survey123 links do not work when using action=edit.
For example, say I have a survey with itemID a62hh5926b1c429eb9f13ab2683c0a16. The following URL works to open a new instance of the survey in the field app and automatically return to Field Maps once the survey is submitted, cancelled, or saved as a draft.
https://survey123.arcgis.app?itemID=a62hh5926b1c429eb9f13ab2683c0a16&callback=https://fieldmaps.arcgis.app
However, if I include action=edit and the filter parameter in the URL in order to open an existing record for editing, as shown below, then the callback fails—nothing happens when the survey is submitted, edited, or saved.
https://survey123.arcgis.app?itemID=a62hh5926b1c429eb9f13ab2683c0a16&action=edit&filter=globalid:aa79348f-ebc5-433a-b61e-653cf0ec49f6&callback=https://fieldmaps.arcgis.app
I'm running version 3.14.242 of the field app. I have tried other variations on the parameters, and switching to the arcgis-survey123:// URL scheme, all with the same results.
