I just want to confirm that there is no way to show the label and not the name, without adding a new calculation field.
We are creating a survey with a lot of select one quistions. Then we have another survey that are pulling in all the data in a read only survey, so basically just a document. To make it more readable I want to remove the box graphic drop down, but just show plain text, by changing the field in the second survey from select_one to note. I'm using a submission_url and this is actually working, except the fact that it is showing the name and not the label in the Survey.
I really want to prevent to add additional 50 fields to the feature service in a already 370 field service..
So I want to have the same functionality as jr:choice-name but without the calculation field.
Possible?
Thanks.
