Hi all,
I'm racking my brain over how to achieve something and so far I'm not having much luck. I've deployed a survey with multiple choice questions built off of a feature class that uses a few coded domains, the results from which are published to our 10.8.1 Portal deployment. The problem I've run into is that records with multiple selections for a given question don't decode correctly in the associated Portal service, i.e. the coded values are rendered instead of the plain language descriptions. Single selections decode fine, but any field containing more than one CSV domain code stay that way--they don't decode.
I get why this is happening, but I'm curious to know if anyone knows of a workaround to force decoding of multiple values in one field.
Thanks!
Ben
