I have a lengthy Survey123 form that has many repeats and groups. When I try to generate a report within Survey123 for one selected record, it gives an error saying that the report couldnt render "GeoshapeTwo". These geometries are point, line and polygon and are conditional based off of a previous answer to display in the form. Should I mark each geometry as Null if the particular geometry is not being used? Attached is the survey if that is easier to interpret!
Edit: To add more context. here is the error I am getting. I have zero idea on what is going and why this map wont print.
An error occurred when rendering by the report engine. Failed to print map for ${geoshapeone}. Error: Failed to print map: {"name":"request:server","message":"Error","details":{"url":"https://services3.arcgis.com/wFnPaTXR2VP4BFs9/arcgis/rest/services/service_d9d724519ad7403e969dbe51a49ecdad/FeatureServer/2/query","requestOptions":{"query":{"f":"json","returnExtentOnly":true,"returnCountOnly":true,"objectIds":"3","spatialRel":"esriSpatialRelIntersects"},"responseType":"json"},"ssl":false,"httpStatus":400,"messages":["This operation is not supported."],"raw":{"code":400,"message":"","details":["This operation is not supported."]}}}
